Stat > ANOVA > General MANOVA > Results
Display certain MANOVA and ANOVA output, display means, and customize MANOVA tests.
Display of Results
Matrices (hypothesis, error, partial correlations): Check to display the hypothesis matrix H, the error matrix E, and a matrix of partial correlations. See MANOVA tests.
Eigen analysis: Check to display the eigenvalues and eigenvalues for the matrix E**-1 H.
Univariate analysis of variance: Check to perform a univariate analysis of variance for each response variable.
Display least squares means corresponding to the terms: Enter terms for which to display a table of means. For example, if you specify A B D A*B*D, four table of means will be displayed, one for each main effect, A, B, D, and one for the three-way interaction, A*B*D.
Custom multivariate tests for the following terms: Enter terms for which to perform 4 multivariate tests. See Specifying terms to test. By default the tests are performed for all model terms.
Error: Enter an error term for the four multivariate tests. It must be a single term that is in the model. If you do not specify an error term, Minitab uses the error associated with mean squares error, as in the univariate case.
