Stat > ANOVA > General MANOVA > Storage
Stores the residuals, fitted values, and many other diagnostics for further analysis (see Checking your model).
Storage
Coefficients: Check to store the coefficients for a model that corresponds to the design matrix. (If M1 contains the design matrix and C1 the coefficients, then M1 times C1 gives the fitted values.)
Fits: Check to store the fitted values.
Residuals: Check to store the residuals.
Standardized residuals: Check to store the standardized residuals.
Deleted t residuals: Check to store Studentized residuals.
Hi [leverage]: Check to store leverages.
Cook's distance: Check to store Cook's distance.
DFITS: Check to store DFITS.
Design matrix: Check to store the design matrix corresponding to your model.
