Interaction Plot - Options
Stat > ANOVA > Interaction Plot > Options
Allows you control the y scale minima and maxima and to add a title to the interaction plot.
Minimum for Y (response) scale: Enter either a single scale minimum for all responses or one scale minimum for each response (separated by spaces).
Maximum for Y (response) scale: Enter either a single scale maximum for all responses or one scale maximum for each response (separated by spaces).
Title: To replace the default title with your own custom title, type the desired text in this box.
