Overview of Balanced ANOVA and GLM
overview
Balanced ANOVA and general linear model (GLM) are ANOVA procedures for analyzing data collected with many different experimental designs. Your choice between these procedures depends upon the experimental design and the available options. The experimental design refers to the selection of units or subjects to measure, the assignment of treatments to these units or subjects, and the sequence of measurements taken on the units or subjects. Both procedures can fit univariate models to balanced data with up to 31 factors. Here are some of the other options:
Balanced ANOVA
GLM
Can fit unbalanced data
no
yes
Can specify factors as random and obtain expected means squares
yes
yes
Fits covariates
no
yes
Performs multiple comparisons
no
yes
Fits restricted/unrestricted forms of mixed model
yes
unrestricted only
Stores a model for further analyses
no
yes
You can use balanced ANOVA to analyze data from balanced designs. See Balanced designs. You can use GLM to analyze data from any balanced design, though you cannot choose to fit the restricted case of the mixed model, which only balanced ANOVA can fit. See Restricted and unrestricted form of mixed models.
To classify your variables, determine if your factors are:
·    crossed or nested
·    fixed or random
·    covariates
For easy entering of repeated factor levels into your worksheet, see Using patterned data to set up factor levels.
