To perform a test for equal variances
main topic see also
1 Choose Stat
> ANOVA > Test for Equal Variances.
2 Choose
one of the following from the drop-down list:
· If
all of the response data for all groups or factor levels is in the same
column, then choose Response
data are in one column for all factor levels. Then do the following:
1 In
Response, enter
the column that contains the response data.
2 In
Factors, enter
the columns that identify the group or factor level
for each row.
· If
the response data for each group or factor level is in a separate column,
then choose, Response
data are in a separate column for each factor level. Then, in Responses, enter the
columns that contain the response data.
3 If you like, use any dialog
box options, then click OK.
