Stat > Basic Statistics > 1-Sample Poisson rate > Options
Specify:
Confidence level: Enter the level of confidence desired. Enter any number between 0 and 100; entries between 0 and 1 are interpreted as percentages. Therefore, entering either 90 or 0.9 will result in a 90% confidence interval. The default is 95.
Alternative
hypothesis: Choose
Rate < hypothesized rate (lower-tailed), not Rate hypothesized rate (two-tailed), or Rate > hypothesized
rate (upper-tailed). If you choose a lower-tailed or an upper-tailed hypothesis
test, Minitab calculates an upper or lower confidence bound, respectively,
instead of a full confidence interval.
Method: Choose to use the exact method or the normal approximation method to calculate the hypothesis test and confidence interval.
Length of observation (time, items, area, etc.): Enter the length of the observation period. The default value is 1.
