1 Choose Stat > Basic Statistics > 1-Sample Poisson Rate.
2 Do one of the following:
1 Choose One or more samples, each in a column, and enter the columns containing the raw data in Sample columns. Minitab performs a separate analysis for each sample.
2 If your data consist of one column of unique values and a separate column for their frequencies, enter the column of frequencies in Frequency columns (optional).
1 Choose Summarized data.
2 In Sample size, enter a single numeric integer for the sample size. You can analyze multiple summarized samples simultaneously if they have equal sample sizes.
3 In Total occurrences, enter one or more numeric integers for the total number of occurrences in each sample. Minitab performs a separate analysis for each sample, and applies the single value in Sample size to all summarized samples.
3 If you want to perform a hypothesis test on the rate of occurrence, check Perform hypothesis test, and enter the hypothesized value for the test in Hypothesized rate.
4 If you like, use any dialog box options, and click OK.
