1-Sample t
overview
    how to     example     data     see also
Stat > Basic Statistics > 1-Sample t
Performs a one-sample t-test or t-confidence interval for the mean.
Use 1-Sample t to compute a confidence interval and perform a hypothesis test of the mean when the population standard deviation, s, is unknown. For a two-tailed one-sample t,
H0: m = m 0   versus   H1: mm 0
where m is the population mean and m 0 is the hypothesized population mean.
One or more samples, each in a column: Choose if you have entered raw data in columns. Enter the columns containing the sample data.
Summarized data: Choose if you have summary values for the sample size, mean, and standard deviation.
Sample size: Enter the value for the sample size.
Sample mean: Enter the value for the sample mean.
Standard deviation: Enter the value for the sample standard deviation.
Perform hypothesis test: Check to perform the hypothesis test.
Hypothesized mean: Enter the test mean m 0.
<Options>
<Graphs>
