Data - 2-Sample Poisson Rate
You can enter the sample data in raw, frequency, or summarized form. Only raw and frequency data use a Minitab worksheet, and their data must consist of nonnegative integers. Minitab excludes missing values from all computations.
Raw data
All values from each sample are present in a column. If you want to enter raw data, do one of the following:
·    Enter data from each sample in a separate column (unstacked data).
·    Enter data from both samples into a single column (stacked data) with a separate column of subscripts identifying from which sample each item originates.
 Here are two ways of entering the same raw data:
Unstacked raw data
Stacked raw data
Defects A
Defects B
Defects
Subscripts
A
A
A
A
A
B
B
B
B
B
B
B
Frequency data
For each sample, unique observations exist in a single column, and their corresponding frequencies exist in a separate column. If you want to enter frequency data, do one of the following:
·    Enter unique values from each sample in a separate column (unstacked data), and enter their frequencies in two more distinct columns.
·    Enter unique values for each sample in a single column, enter subscripts identifying the sample of origin in a second column, and enter frequencies for each unique value in a third column.
Here are two ways of entering the above data in frequency format:
Unstacked frequency data
Stacked frequency data
Defects A
Defects B
Frequency A
Frequency B
Defects
Subscripts
Frequencies
A
A
A
A
B
B
B
B
Summarized data
Enter the sample size and the number of occurrences for each sample directly in the 2-Sample Poisson Rate dialog box.
To input the above data in summarized form, do the following:
1    Choose Summarized data.
2    In First, enter 5 (the sum of the Frequency A column) for Sample size and enter 11 (the sum of the unstacked Defects A column) for Total occurrences.
3    In Second, enter 7 (the sum of the Frequency B column) for Sample size and enter 20 (the sum of the unstacked Defects B column) for Total occurrences.
