1 Choose Stat > Basic Statistics > 2-Sample Poisson Rate
2 Do one of the following:
1 Choose Both samples are in one column.
2 In Samples, enter the columns containing the samples' data.
3 In Sample IDs, enter the column containing the subscripts identifying from which sample each item originates.
4 If your column of stacked data contains only unique values, enter a separate column of their corresponding frequencies in Frequency column.
1 Choose Each sample is in its own column.
2 In Sample 1, enter the column containing the first sample.
3 In Sample 2, enter the column containing the second sample.
4 If, for each sample, you have a column of unique values and a separate column of corresponding frequencies, enter the columns of frequencies in Frequency columns.
1 Choose Summarized data.
2 In Sample 1, enter values for Sample size and Total occurrences for the first sample.
3 In Sample 2, enter values for Sample size and Total occurrences for the second sample.
3 If you like, use any dialog box options, and click OK.
