To perform a two-sample variance test
main topic see also
1 Choose Stat
> Basic Statistics > 2 Variances.
2 Choose
one of the following from the drop-down list:
· Both
samples are in one column: Choose if the sample data are in a single
column, and are differentiated by sample IDs in a second column.
Samples:
Enter the column that contains the data for both samples.
Sample
IDs: Enter the column that indicates which sample each observation
belongs to.
· Each
sample is in its own column: Choose if the data for each sample
is in a different column.
Sample
1: Enter the column that contains the data for the first sample.
Sample
2: Enter the column that contains the data for the second sample.
· Sample
standard deviations: Choose to enter summary values for the sample
size and standard deviation of each sample. For summary data, only the
F-test can be performed. The F-test
is accurate only for normally distributed data.
Sample
size: Enter the sample size for each sample.
Standard
deviation: Enter the standard deviation for each sample.
· Sample
variances: Choose to enter summary values for the sample size and
variance of each sample. For summary data, only the F-test
can be performed. The F-test is accurate only for normally distributed
data.
Sample
Variance:
Enter the variance for each sample.
3 If you like, use any dialog
box options.
4 Click
OK.
