Stat > Basic Statistics > Store Descriptive Statistics > Statistics
Allows you to choose the statistics that you wish to store.
Mean: Choose to store the arithmetic mean.
SE of mean: Choose to store the standard error of the mean.
Standard deviation: Choose to store the standard deviation of the data.
Variance: Choose to store the variance of the data.
Coefficient of variation: Choose to store the coefficient of variation.
First quartile: Choose to store the first quartile.
Median: Choose to store the median.
Third quartile: Choose to store the third quartile.
Interquartile range: Choose to store the difference between the first and third quartiles.
Trimmed mean: Choose to store the trimmed mean.
Sum: Choose to store the data sum.
Minimum: Choose to store the data minimum.
Maximum: Choose to store the data maximum.
Range: Choose to store the data range.
N nonmissing: Choose to store the number of nonmissing column entries.
N missing: Choose to store the number of missing column entries.
N total: Choose to store the total (nonmissing and missing) number of column entries.
Cumulative N: Choose to store the cumulative number of entries.
Percent: Choose to store the percent of observations that a group constitutes. The percent will be 100 unless you use a By variable.
Cumulative percent: Choose to store the cumulative percent.
Sum of squares: Choose to store the sum of the squared data values. This is the uncorrected sums of squares, without first subtracting the mean.
Skewness: Choose to store the skewness value.
Kurtosis: Choose to store the kurtosis value
MSSD: Choose to store half the Mean of Successive Squared Differences.
