2-Sample Equivalence Test - Options
Stat > Equivalence Tests > 2-Sample > Options
Choose the significance level (also known as alpha or a) and other options for the test.
Risk level of claiming equivalence when it is not true (alpha): Specify the significance level for the test. 0.05 is the most common choice.
Use (1 - 2 alpha) x 100% confidence interval: Check to use an alternative method to calculate the confidence interval of the difference between (or ratio of) the means. The alternative method may give you the same upper confidence limit and lower confidence limit as the default method. The confidence level for the alternative method is always smaller than that of the default method. For example, if a is 0.05, then the confidence level for the alternative method is 90%, rather than 95% for the default method.
Assume equal variances: Check this option if you are confident that the variances of the two populations are equal. You can base this decision on prior knowledge or on a 2 variances test.
Calendar with week numbers
US Federal Holidays
Australia Public Holidays
