Data - 2x2 Crossover Design Equivalence
Test
Data can be entered in the following ways:
· Four
columns: Each column contains the data for one period of one sequence.
Both values for each participant must be in the same row.
· Three columns:
One column contains the data for Period 1. A second column contains the
data for Period 2. A third column identifies the sequence for each row.
The sequence IDs can be numeric, text, or date/time, for example, "Sequence
A" and Sequence B", or 1 and 2. Both values for each participant
The sample sizes for the two sequences do not need to be equal.
