Stat > Equivalence Tests > 2x2 Crossover Design > Graphs
Display graphs to summarize the results and to compare the distributions of the samples.
Equivalence plot: Check to display a graphical summary of the equivalence test results. The equivalence plot includes the confidence interval for the difference (or ratio), as well as the equivalence limits and the decision about whether you can claim equivalence.
Subject profile plot: Check to display a graph that shows the difference between the test response and the reference response for each participant in each sequence.
Period plot: Check to display a plot of Period 1 responses on the x-axis against Period 2 responses on the y-axis. Each sequence is represented by a different symbol.
Sequence by period mean plot: Check to display a graph that shows the mean response for each of period of each sequence.
