Stat > Equivalence Tests > 2x2 Crossover Design > Results
Choose the results to display.
Method: Check to display the method information, including the treatment order for each sequence.
Descriptive statistics: Check to display descriptive statistics for each sample, including the number of observations and the mean for each sample.
Effects: Check to show the analyses for the carryover, treatment, and period effects.
Difference: (This option is available only if the difference hypothesis is chosen.) Check to display the difference information, including the difference between the means, the confidence interval for the difference, the equivalence interval, and the decision about whether you can claim equivalence.
Ratio: (This option is available only if a ratio hypothesis is chosen.) Check to display the ratio information, including the ratio of the means, the confidence interval for the ratio, the equivalence interval, and the decision about whether you can claim equivalence. If you choose to compare the ratio by taking the log transformation of the original data, Minitab also displays the difference between the means after log transformation.
Test: Check to display the results of the test, including the hypotheses, the p-value for the test of each hypothesis, and the decision about whether you can claim equivalence.
