1 Choose Stat > Equivalence Tests > 2x2 Crossover Design.
2 Select the appropriate layout for your data.
1 In Treatment order for sequence 1, indicate the order of the treatments for Sequence 1.
2 In each box, enter the column that contains the data for the appropriate period and sequence.
1 In Sequence ID, enter the column that identifies which sequence each row belongs to.
2 In Response from period 1, enter the column that contains the data from Period 1.
3 In Response from period 2, enter the column that contains the data from Period 2.
4 In Treatment order for sequence, enter the ID value for the sequence that received the reference treatment in Period 1.
3 In Hypothesis about, indicate how you want to express your hypothesis.
4 From What do you want to determine, choose the appropriate form of the alternative hypothesis.
5 Enter a value for the Lower limit, Upper limit, or both if applicable.
6 If you are testing the difference between means, and the limits are expressed as a proportion of the reference mean, then check Multiply by reference mean.
7 Click OK.
