To perform an equivalence test with paired data
1    Choose Stat > Equivalence Tests > Paired.
2    In Test sample, enter the column that contains the data from the test sample.
3    In Reference sample, enter the column that contains the data from the reference sample. Ensure that you specify correctly which is the test sample and which is the reference sample.
4    In Hypothesis about, indicate how you want to express your hypothesis.
5    From What do you want to determine, choose the appropriate form of the alternative hypothesis.
6    Enter a value for the Lower limit, Upper limit, or both if applicable.
7    If you are testing the difference between means, and the limits are expressed as a proportion of the reference mean, then check Multiply by reference mean.
8    Click OK.
