You must use raw data as input to K-means clustering of observations. Each row contains measurements on a single item or subject. You must have two or more numeric columns, with each column representing a different measurement. You must delete rows with missing data from the worksheet before using this procedure.
To initialize the clustering process using a data column, you must have a column that contains a cluster membership value for each observation. The initialization column must contain positive, consecutive integers or zeros (it should not contain all zeros). Initially, each observation is assigned to the cluster identified by the corresponding value in this column. An initialization of zero means that an observation is initially unassigned to a group. The number of distinct positive integers in the initial partition column equals the number of clusters in the final partition.
