Cluster K-Means - Storage
Stat > Multivariate > Cluster K-Means > Storage
Allows cluster membership for each observation and the distance between each observation and each cluster centroid.
Cluster membership column: Enter a single storage column for final cluster membership for each observation. This column can then be used as a categorical variable in other Minitab commands, such as Discriminant Analysis or Plot.
Distance between observations and cluster centroids (Give a column for each cluster group): Enter storage columns for the distance between each observation and each cluster centroid. The number of columns specified must equal the number of clusters specified for the initial partition. The distances stored are Euclidean distances.
