Cross-Validation
Cross-validation is one technique that is used to compensate for an optimistic apparent error rate. The apparent error rate is the percent of misclassified observations. This number tends to be optimistic because the data being classified are the same data used to build the classification function.
The cross-validation routine works by omitting each observation one at a time, recalculating the classification function using the remaining data, and then classifying the omitted observation. The computation time takes approximately four times longer with this procedure. When cross-validation is performed, Minitab displays an additional summary table.
Another technique that you can use to calculate a more realistic error rate is to split your data into two parts. Use one part to create the discriminant function, and the other part as a validation set. Predict group membership for the validation set and calculate the error rate as the percent of these data that are misclassified.
