Factor Analysis - Results
Stat > Multivariate > Factor Analysis > Results
Controls the display of Session window results.
Display of Results:
Do not display: Choose to suppress the display of results. All requested storage is done.
Loadings only: Choose to display loadings (and sorted loadings if requested) for the final solution.
Loadings and factor score coefficients: Choose to display factor loadings and scores.
All and MLE iterations: Choose to display the factor loadings, factor scores and information on the iterations if a maximum likelihood estimation was used.
Sort loading: Check to sort the loadings in the Session window (within a factor if the maximum absolute loading occurs there).
Zero loading less than: Check to enter a value. Loadings less than this value will be displayed as zero.
