Multivariate Analysis Overview
Use Minitab's multivariate analysis procedures to analyze your data
when you have made multiple measurements on items or subjects. You can
choose to:
· Analyze
the data covariance structure to understand it or to reduce the data dimension
· Assign
observations to groups
· Explore
relationships among categorical variables
Because Minitab does not compare tests of significance for multivariate
procedures, interpreting the results is somewhat subjective. However,
you can make informed conclusions if you are familiar with your data.
Analysis of the data structure
Minitab offers two procedures for analyzing the data covariance structure:
· Principal Components
helps you to understand the covariance structure in the original variables
and/or to create a smaller number of variables using this structure.
· Factor Analysis, like principal
components, summarizes the data covariance structure in a smaller number
of dimensions. The emphasis in factor analysis is the identification of
underlying "factors" that might explain the dimensions associated
with large data variability.
Internal Consistency
· Item
Analysis assesses how reliably multiple items in a survey or test
measure the same construct.
Grouping observations
Minitab offers three cluster analysis methods and discriminant analysis
for grouping observations:
· Cluster Observations
groups or clusters observations that are "close" to each other
when the groups are initially unknown. This method is a good choice when
no outside information about grouping exists. The choice of final grouping
is usually made according to what makes sense for your data after viewing
clustering statistics.
· Cluster Variables groups
or clusters variables that are "close" to each other when the
groups are initially unknown. The procedure is similar to clustering of
observations. You may want to cluster variables to reduce their number.
· Cluster K-Means, like
clustering of observations, groups observations that are "close"
to each other. K-means clustering works best when sufficient information
is available to make good starting cluster designations.
· Discriminant Analysis
classifies observations into two or more groups if you have a sample with
known groups. You can use discriminant analysis to investigate how the
predictors contribute to the groupings.
Correspondence Analysis
Minitab offers two methods of correspondence analysis to explore the
relationships among categorical variables:
· Simple
Correspondence Analysis explores relationships in a 2-way classification.
You can use this procedure with 3-way and 4-way tables because Minitab
can collapse them into 2-way tables. Simple correspondence analysis decomposes
a contingency table similar to how principal components analysis decomposes
multivariate continuous
data. Simple correspondence analysis performs an eigen analysis of data,
breaks down variability into underlying dimensions, and associates variability
with rows and/or columns.
· Multiple
Correspondence Analysis extends simple correspondence analysis to
the case of 3 or more categorical variables. Multiple correspondence analysis
performs a simple correspondence analysis on an indicator variables matrix
in which each column corresponds
to a level of a categorical variable. Rather than a 2-way table, the multi-way
table is collapsed into 1 dimension.
