Stat > Regression > Binary Logistic Regression > Fit Binary Logistic Model > Graphs
Display residual plots for diagnosis of the regression model fit. See Regression diagnostics and residual analysis for more information.
Residuals for Plots: You can specify the type of residual to display on the residual plots. See Choosing a residual type. To choose between Deviance residuals and Pearson residuals, use Options.
Regular: Choose to plot the regular or raw residuals.
Standardized: Choose to plot the standardized residuals.
Deleted: Choose to plot the Studentized deleted residuals.
Residual Plots
Histogram of residuals: Check to display a histogram of the residuals.
Normal probability plot of the residuals: Check to display a normal probability plot of the residuals.
Residuals versus fits: Check to plot the residuals versus the fitted values. This plot is not available when the data are in binary format or frequency format because the resulting pattern would not be informative.
Residuals versus order: Check to plot the residuals versus the order of the data. The row number for each data point is shown on the x-axis. For example, 1 2 3 4... n.
Three in one or Four in one: Choose to display a layout of the residual plots. If the data are in binary format or frequency format, the layout has a histogram of residuals, a normal plot of residuals, and a plot of residuals versus order. If the data are in event/trial format, the layout also has a plot of residuals versus the fits on the link scale.
Residuals versus the variables: Enter one or more columns containing the variables against which you want to plot the residuals. Minitab displays a separate graph for each column.
