Stat > Regression > Fitted Line Plot > Options
Allows you to transform the X and Y variables, display confidence and prediction bands around the fitted regression line, change the confidence level, and add a custom title.
Transformations
Logten of Y: Check to use log10Y as the response variable.
Display logscale for Y variable: Check to plot the transformed Y variable on a log scale.
Logten of X: Check to use log10X as the predictor variable. If you use this option with polynomials of order greater than one, then the polynomial regression will be based on powers of the log10X.
Display logscale for X variable: Check to plot the transformed X variable on a log scale.
Display Options
Display confidence interval: Check to display the confidence interval bands for the prediction about the fitted regression line at the confidence level specified in the box below.
Display prediction interval: Check to display the prediction interval bands about the fitted regression line at the confidence level specified in the box below.
Confidence level: Enter a number between 0 and 100 for the level of confidence you want to use for the confidence and prediction bands. The default is 95.0.
Title: To replace the default title with your own custom title, type the desired text in this box.
