Nominal Logistic Regression - Results
Stat > Regression > Nominal Logistic Regression > Results
Allows you to control the amount of printed output.
Control the Display of Results
Display nothing: Choose to suppress all printed output, but do all requested storage and display graphs.
Response information, regression table, log-likelihood, and test that all slopes equal 0: Choose to print the response information, logistic regression table, log-likelihood, and test that all slopes equal 0.
In addition, 2 goodness-of-fit tests: Choose to print the Pearson and deviance tests in addition to the output described above.
In addition, list of factor level values, and tests for terms with more than 1 degree of freedom: Choose to print factor level values, and tests for terms with more than 1 degree of freedom.
Show log-likelihood for each iteration of algorithm: Check to display the log-likelihood at each iteration of the parameter estimation process.
Calendar with week numbers
US Federal Holidays
Australia Public Holidays
