To do a nominal logistic regression
main topic see also
1 Choose
Stat > Regression > Nominal Logistic
Regression.
2 Do one of the following:
· If
you have raw response data, in Response, enter the numeric column containing
the response data.
· If
you have frequency data, in Response, enter the numeric column containing
the response values. Then, in Frequency, enter the variable containing
the counts.
See Entering
data for response variables.
3 In Model, enter the model terms. See Specifying
a model in logistic regression.
4 If you like, use one or more
of the options listed below, then click OK.
