Stat > Regression > Nonlinear Regression > Results
Control the level of detail in the display of output to the Session window.
Method: Check to display information about the algorithm, maximum number of iterations, and convergence tolerance.
Starting values: Check to display the parameters' starting values.
Constraints: Check to display the constraints placed on the parameter estimates.
Information for each iteration: Check to display information for each iteration, including the parameter estimates and the sum of the squared residuals (SSE).
Regression equation: Check to display the regression equation.
Parameter table: Check to display the parameter estimates and standard errors.
Display confidence intervals: Check to display a confidence interval for each parameter. For some data sets, expectation functions, and confidence levels, one or both confidence bounds may not exist. Minitab indicates missing results with an asterisk in the Session window.
Correlation matrix for the parameter estimates: Check to display the correlation matrix for the parameter estimates.
Summary of fit: Check to display statistics that evaluate model fit, including a lack-of-fit test, a summary of the fit, the number of iterations, the final SSE, the degrees of freedom for error, the mean square error (MSE), and S.
Prediction tables: Check to display fitted values, confidence intervals, and prediction intervals for the new observations specified in the Prediction dialog box.
