Stat > Regression > Nonlinear Regression > Storage
You can store diagnostic measures and characteristics of the estimated regression equation.
Diagnostic Measures
Residuals: Check to store the residuals.
Fits: Check to store the fitted values.
Parameters: Check to store the estimated parameters of the regression equation.
Standard errors of parameters: Check to store the standard error of each parameter estimate.
Grid of starting values and SSE values: Check to store each starting value combination and the corresponding initial sum of the squared residuals (SSE). Minitab performs the nonlinear regression analysis using the starting value combination that produces the smallest initial SSE.
