To perform a nonlinear regression analysis
1    Choose Stat > Regression > Nonlinear Regression.
2    In Response, enter the column that contains the response (Y) variable.
3    In Expectation Function, enter the function that describes the relationship between the predictor(s) and the expected response value. Use one of these methods to enter the function:
·    <Use Catalog>: Click to choose a predefined function.
·    <Use Calculator>: Click to use the calculator to enter a custom function.
·    Edit directly: Enter the function directly into the text box.
4    If you select a function in the catalog, the Choose Predictors dialog appears. Enter the predictor for each placeholder in the equation in Actual Predictor. Click OK.
5    Click Parameters, and enter a starting value for each parameter. Click OK.
6    If you like, use one or more of the dialog box options, then click OK.
