Ordinal Logistic Regression - Results
Stat > Regression > Ordinal Logistic Regression > Results
Allows you to control the amount of printed output.
Control the Display of Results
Display nothing: Choose to suppress all printed output, but do all requested storage and display graphs.
Response information, regression table, log-likelihood, and test that all slopes equal 0: Choose to print the response information, logistic regression table, log-likelihood, and test that all slopes equal 0.
In addition, 2 goodness-of-fit tests, and measures of association: Choose to print the Pearson and deviance tests, and measures of association in addition to the output described above.
In addition, lists of factor level values, and tests for terms with more than 1 degree of freedom: Choose to print factor level values, and tests for terms with more than 1 degree of freedom.
Show log-likelihood for each iteration of algorithm: Check to display the log-likelihood at each iteration of the parameter estimation process.
