To do an ordinal logistic regression
1    Choose Stat > Regression > Ordinal Logistic Regression.
2    Do one of the following:
·    If you have raw response data, in Response, enter the numeric column containing the response data.
·    If you have frequency data, in Response, enter the numeric column containing the response values. Then, in Frequency, enter the variable containing the counts.
See Entering data for response variables.
3    In Model, enter the model terms. See Specify the model terms.
4    If you like, use one or more of the dialog box options, then click OK.
