To perform orthogonal regression
1    Choose Stat > Regression > Orthogonal Regression.
2    In Response (Y), enter the column containing the response variable.
3    In Predictor (X), enter the column containing the predictor variable.
4    In Error variance ratio (Y/X), enter the ratio of the response error variance to the predictor error variance.
5    If you like, use one or more of the dialog box options, then click OK.
