Example of a Poisson regression
     interpreting results     session command
A manufacturer produces molded resin parts. Contamination in hoses and abrasions to resin pellets can lead to discolored streaks in the final product. Higher temperatures and faster rates of transfer can cause pellets to clump together. Clumps can be difficult to move through hoses and into molds. The company collects data on the number of defects per hour.
1    Open the worksheet ResinDefects.MTW.
2    Choose Stat > Regression > Poisson Regression > Fit Poisson Model.
3    In Response enter Discoloration Defects.
4    In Continuous Predictors enter Hours Since Cleanse and Temperature.
5    In Categorical Predictors enter Size of Screw.
6    Click Graphs.
7    In Residuals for Plots, choose Standardized.
8    Under Residual Plots, choose Four in One.
9    Click OK in each dialog box.
Session window output
Poisson Regression Analysis: Discoloratio versus Hours Since , Temperature, Size of Scre
Method
Link function                 Natural log
Categorical predictor coding  (1, 0)
Rows used                     36
Deviance Table
Source                 DF  Adj Dev  Adj Mean  Chi-Square  P-Value
Regression              3   56.670   18.8900       56.67    0.000
  Hours Since Cleanse   1    4.744    4.7444        4.74    0.029
  Temperature           1   38.800   38.8000       38.80    0.000
  Size of Screw         1   13.126   13.1256       13.13    0.000
Error                  32   31.607    0.9877
Total                  35   88.277
Model Summary
Deviance   Deviance
    R-Sq  R-Sq(adj)     AIC
  64.20%     60.80%  253.29
Coefficients
Term                      Coef   SE Coef   VIF
Constant                4.3982    0.0628
Hours Since Cleanse    0.01798   0.00826  1.00
Temperature          -0.001974  0.000318  1.00
Size of Screw
  small                -0.1546    0.0427  1.00
Regression Equation
Discoloration Defects  =  exp(Y')
Size of
Screw
large    Y' = 4.398 + 0.01798 Hours Since Cleanse - 0.001974 Temperature
small    Y' = 4.244 + 0.01798 Hours Since Cleanse - 0.001974 Temperature
Goodness-of-Fit Tests
Test      DF  Estimate     Mean  Chi-Square  P-Value
Deviance  32  31.60722  0.98773       31.61    0.486
Pearson   32  31.26713  0.97710       31.27    0.503
Fits and Diagnostics for Unusual Observations
     Discoloration
Obs        Defects    Fit  Resid  Std Resid
 33          43.00  58.18  -2.09      -2.18  R
R  Large residual
Interpreting the results
·    The p-value for the regression model in the Analysis of Deviance table (0.000) shows that the model estimated by the regression procedure is significant at an a-level of 0.05. This indicates that at least one coefficient is different from zero.
·    The deviance R2 value indicates that the predictors explain 64.20% of the variance in the number of discolorations. The adjusted deviance R2  is 60.80%, which accounts for the number of predictors in the model. Use these values to compare this model to other models.
·    The Akaike Information Criterion (AIC) value is 253.29. Use the AIC to compare different models. The smaller the AIC, the better.
·    The coefficient for Hours Since Cleanse is 0.01798. Because the model uses the natural log link function and the coefficient is small, the coefficient indicates that the number of discolorations increases by about 1.8% each hour. See Interpreting the parameter estimates for more details.
·    One observation has a standardized residual less than -2. This point is not fit well by the model. Because the residuals show that the model is inadequate, you cannot evaluate whether the points are unusual yet.
Graph window output
·    The normal probability plot shows an approximately linear pattern consistent with a normal distribution. To investigate individual points, brush the graph.
·    The plot of the residuals versus the fitted values shows a distinct curve. This pattern indicates the model is inadequate. For these data, the pattern is because the size of the screw and the temperature interact but the interaction term is not in the model. The results are not reliable until you add the interaction term and the residual plots are satisfactory.
·    On the histogram, no residuals look unusual. Three residuals are in bins that include -2 and 2.  You can verify that one of the residuals is less than -2 on the other residual plots.
·    The plot of the residuals versus order begins with 9 negative residuals. The middle portion of the residuals tends to be higher than the residuals at the beginning and end of the data set. For these data, the pattern is also because of the missing interaction. The missing interaction looks like a time effect because the data were not collected in a random order.
See Checking your model and Identifying outliers for more information about residual plots.
Calendar with week numbers
US Federal Holidays
Australia Public Holidays
