Fit Regression Model - Graphs
Stat > Regression > Regression > Fit Regression Model > Graphs
Display residual plots for diagnosis of the regression model fit.
Residuals for Plots: You can specify the type of residual to display on the residual plots. See Choosing a residual type.
Regular: Choose to plot the regular or raw residuals.
Standardized: Choose to plot the standardized residuals.
Deleted: Choose to plot the Studentized deleted residuals.
Residual Plots
Histogram of residuals: Check to display a histogram of the residuals.
Normal probability plot of the residuals: Check to display a normal probability plot of the residuals.
Residuals versus order: Check to plot the residuals versus the order of the data. The row number for each data point is shown on the x-axis. For example, 1 2 3 4... n.
Residuals versus the variables: Enter one or more columns containing the variables against which you want to plot the residuals. Minitab displays a separate graph for each column.
