Stat > Regression > Regression > Fit Regression Model > Coding
Use to:
Standardizing the continuous predictors can improve the interpretation of the model for specific conditions. You can standardize the continuous predictors using the following methods:
Coding for categorical predictors: Use when you have categorical predictors. To perform the analysis, Minitab needs to recode the categorical data. Base your decision on whether you want to compare the levels to the overall mean or the mean of a reference level.
(- 1, 0, +1): Choose to estimate the difference between each level mean and the overall mean.
(1, 0): Choose to estimate the difference between each level mean and the reference level's mean.
Categorical predictor reference level: If you choose the (1, 0) coding scheme, the reference level table becomes active in the dialog box. Minitab compares the means of the nonreference level(s) to the reference level. Changing the reference level does not affect the overall significance, but it can make the results more meaningful.
Categorical predictor: Shows all the names of categorical predictors in your model. This column does not take any input.
Reference level: Choose a reference level for each categorical predictor.
Standardize continuous predictors: Use to control whether Minitab standardizes the continuous predictors. The standardized predictors are only used to fit the model and are not stored in the worksheet.
Do not standardize: Choose to use your original data for the continuous predictors.
Subtract the mean, then divide by the standard deviation: Choose to both center the predictors and to place them on a comparable scale.
Subtract the mean: Choose to center the predictors.
Divide by the standard deviation: Choose to use a comparable scale for all predictors.
Subtract a specified value, then divide by another: Choose to specify values rather than the mean and standard deviation estimates from the sample.
Continuous predictor: Shows all of the names of continuous predictors in your model. This column does not take any input.
Subtract: Type the value to subtract from each continuous predictor.
Divide by: Type the value that Minitab uses to divide the result of the subtraction.
Specify low and high levels to code as -1 and +1: Choose to transform the data linearly. All data values that fall between the Low and High values that you specify are coded to fall between -1 and +1. Designed experiments (DOE) use this scheme.
Low: Type a value to code as -1. The default is the minimum value in the sample.
High: Type a value to code as +1. The default is the maximum value in the sample.
