Stat > Regression > Regression > Response Optimizer > Setup
Specify the boundaries, weight, and importance for each response variable. You can use the default values or enter your own values. The defaults are as follows:
Goal |
Lower |
Target |
Upper |
Maximize |
Minimum observation |
Maximum observation |
Disabled |
Minimize |
Disabled |
Target |
Target from main dialog |
Response: Displays all of the responses that are included in the optimization. This column does not take any input.
Goal: Displays the goal for each response. This column does not take any input.
Lower: For each response that has a goal of Target or Maximize, enter a lower boundary.
Target: Enter a target value for each response.
Upper: For each response that has a goal of Minimize or Target under Goal, enter an upper boundary.
Weight: Enter a number from 0.1 to 10 to define the shape of the desirability function.
Importance: Enter a number from 0.1 to 10 to specify the comparative importance of the response.
