Decomposition - Storage
Stat > Time Series > Decomposition > Storage
Stores various values in the worksheet.
Trend line: Check to store the trend component data. This is the trend component; it does not contain the error or seasonal component.
Detrended data: Check to store the detrended data (has seasonal and error components, no trend)
Seasonals: Check to store the seasonal component data (has seasonal component, no error or trend).
Seasonally adjusted data: Check to store the data which has had the seasonal component removed (has trend and error components, no seasonal).
Fits: Check to store the fitted values. These are the combination of trend and seasonal components, with no error component.
Residuals: Check to store the residuals. If you store the residuals you can generate diagnostic plots using Autocorrelation.
Forecasts: Check to store the forecasts. This option is available only if you generated forecasts in the main Decomposition dialog box.
