Double Exponential Smoothing - Graphs
Stat > Time Series > Double Exp Smoothing > Graphs
Displays time series plot and residual plots for diagnosis of model fit.
Time series plot (including optional forecasts)
Plot predicted vs. actual: Choose to generate a time series plot which displays the data and one-period-ahead forecasts, or fitted values.
Plot smoothed vs. actual: Choose to generate a time series plot which displays the data and the smoothed, or moving average, values.
Do not display plot: Choose to suppress the time series plot.
Residual Plots
Histogram of residuals: Check to display a histogram of the residuals.
Normal plot of residuals: Check to display a normal probability plot of the residuals.
Residuals versus order: Check to plot the residuals versus the order of the data. The row number for each data point is shown on the x-axis-for example, 1 2 3 4... n.
Residuals versus the variables: Enter one or more columns containing the variables against which you want to plot the residuals. Minitab displays a separate graph for each column.
