Double Exponential Smoothing - Storage
Stat > Time Series > Double Exp Smoothing > Storage
Stores various items in the worksheet.
Smoothed data: Check to store the smoothed data.
Level estimates: Check to store the level components. The level component at time T equals the smoothed value at time T, while adding the level and trend components at time T equals the one-period-ahead forecast for time T+1.
Trend estimates: Check to store the trend components.
Fits (one-period-ahead-forecasts): Check to store the fitted values. You should store the fitted values if you want to generate diagnostic residual plots.
Residuals: Check to store the residuals. The residual at time T is the difference between the actual data at time T and the fitted value at time T. These residuals are used to calculate MAPE, MAD and MSD. If you store the residuals you can generate diagnostic plots using Autocorrelation.
Forecasts: Check to store the forecasts. This option is available only if you generated forecasts in the main Double Exponential Smoothing dialog box.
Upper 95% Prediction Interval: Check to store the upper 95% prediction limits for the forecasts.
Lower 95% Prediction Interval: Check to store the lower 95% prediction limits for the forecasts.
Calendar with week numbers
US Federal Holidays
Australia Public Holidays
