Centering Moving Average Values
By default, moving average values
are placed at the period in which they are calculated. For example, for
a moving average length of 3, the first numeric moving average value is
placed at period 3, the next at period 4, and so on.
When you center the moving averages, they are placed at the center of
the range rather than the end of it. This is done to position the moving
average values at their central positions in time.
· If the moving average length is odd:
Suppose the moving average length is 3. In that case, Minitab places the
first numeric moving average value at period 2, the next at period 3,
and so on. In this case, the moving average value for the first and last
periods is missing ( *).
· If the moving average length is even:
Suppose the moving average length is 4. The center of that range is 2.5,
but you cannot place a moving average value at period 2.5. This is how
Minitab works around the problem. Calculate the average of the first four
values, call it MA1. Calculate the average of the next four values, call
it MA2. Average those two numbers (MA1 and MA2), and place that value
at period 3. Repeat throughout the series. In this case, the moving average
values for the first two and last two periods are missing ( *).
