Stat > Time Series > Single Exp Smoothing > Storage
Stores the smoothed values, the fits or predicted values (smoothed value at time t -1), the residuals (data - fits), forecasts, and upper and lower 95% prediction limits.
Smoothed data: Check to store the smoothed data. The smoothed value at time T is the fitted value for time T+1.
Fits (one-period-ahead forecasts): Check to store the fitted values. You should store the fitted values if you want to generate diagnostic residual plots.
Residuals: Check to store the residuals. The residual at time T is the difference between the actual data at time T and the fitted value at time T. These residuals are used to calculate MAPE, MAD and MSD. If you store the residuals you can generate diagnostic plots using Autocorrelation.
Forecasts: Check to store the forecasts. This option is available only if you generated forecasts in the main Single Exponential Smoothing dialog box.
Upper 95% Prediction Interval: Check to store the upper 95% prediction limits for the forecasts.
Lower 95% Prediction Interval: Check to store the lower 95% prediction limits for the forecasts.
