A type of designed experiment that allows for the simultaneous study of the effects that several factors may have on a response. When performing an experiment, varying the levels of all factors simultaneously rather than one at a time allows for the study of interactions between the factors.
In the following plots, each point represents a unique combination of factor levels.
Two Factor Design |
Three Factor Design |
2 levels of factor A |
2 levels of each factor |
You can either run the full factorial design or a fraction of the factorial design:
