Cube Plot
Factorial Designs
Summary
Use a cube plot to see the factors and combination of settings used in your design. Optionally, you can add a mean response at each setting.
Data Description
A building materials manufacturer is developing a new insulation product for construction. They would like to study four factors that are believed to impact the strength (Strength) of the insulation. The four factors are
·    material type (Material)
·    injection temperature (InjTemp)
·    injection pressure (InjPress)
·    cooling temperature (CoolTemp)
They also recorded the temperature at the time of the strength measurement (MeasTemp), which is included as a covariate in the model.
Data: Insulation2.MTW (available in the Sample Data folder).
