Tolerance IntervalsMethods |
Minitab details the type of tolerance interval that you specified:
Method
Confidence level 95% Percent of population in interval 95% |
For the washer data, Minitab creates a two-sided tolerance interval that states with 95% confidence that at least 95% of the population has measurements falling within the tolerance limits.
