Normal and nonparametric methods for tolerance intervals
When
you calculate tolerance intervals using Stat > Quality Tools > Tolerance
Intervals, Minitab displays results for both the normal and nonparametric
methods. Minitab also displays results for both methods when you plan
for tolerance intervals using Stat > Power and Sample Size > Sample
Size for Tolerance Intervals. To determine which method to use, consider
the following:
· If
your data follow a normal distribution, then the normal method is more
precise and economical than the nonparametric method. The normal method
allows you to achieve smaller margins of error [link] with fewer observations.
Use the normal method if you know from prior experience or analysis that
your population is normally distributed. A normality test, such as the
one that is included with Stat > Quality Tools > Tolerance Intervals,
can also help you decide.
· The
normal method is not robust to severe departures from normality. If you
are unsure of the parent distribution, or you know that the parent distribution
is not normal, then use the nonparametric method. The nonparametric method
requires only that the data are continuous.
· The
nonparametric method requires large sample sizes to cover a large percentage
of the population. If your sample size is not large enough, the achieved
confidence level for your tolerance interval can be much lower than the
desired level.
Minitab uses an exact method to calculate normal tolerance intervals.
Minitab's sample size planning for normal tolerance intervals also uses
an exact method.
