Moving Range ChartTest Results |
The moving range (MR) chart assesses whether the process variation is in control. The tests for special causes detect points beyond the control limits and specific patterns in the data.
No points failed the tests for special causes.
The liquid detergent data did not fail any of the tests for special causes. Therefore, the process variation is in control.
