Display Descriptive StatisticsDispersion - Minimum and Maximum |
One of the simplest ways to assess dispersion in your data is to compare the minimum and maximum. The minimum is the smallest value in a data set, and the maximum is the largest value.
Minimum and maximum are used to calculate the range, which is a statistic that is often used to describe dispersion in data sets. The range is simply the maximum - minimum. Notice that the range is very sensitive to extreme values.
Variable N N* Mean SE Mean StDev Minimum Precipitation 11 1 3.636 0.717 2.378 1.000
Precipitation 2.000 3.000 4.000 10.000 |
For the precipitation data the minimum is 1 and the maximum is 10.
For the precipitation data the range is: 10 - 1 = 9
Even though most of the data lies between the values of 1 and 5 (a range of 4), the extreme value of 10 results in a range of 9 for the sample.
