Binary Logistic RegressionRegression Table - Odds Ratio |
One advantage of the logit link function is that it provides an estimate of the odds ratio for each predictor in the model. The larger the odds ratio, the greater are the odds of a predictor impacting the binary response relative to the predictor's reference level. An odds ratio of 1 indicates no association between the predictor and response.
Odds Ratios for Continuous Predictors
Unit of Odds Predictor Change Ratio 95% CI Income 1 1.014 (0.98, 1.05)
Odds Ratios for Categorical Predictors
Odds Predictor Reference Ratio 95% CI Children Yes No 4.190 (0.78, 22.45) ViewAd Yes No 2.813 (0.92, 8.63) |
For the cereal data, the logit link was used, therefore the odds ratios can be interpreted as:
