Binary Logistic RegressionMeasures of Association |
The Measures of Association table contains the following:
To create the pairs used in these statistics, each observed "success" is paired with every "failure." It is then noted whether the probability of success predicted from the model is higher for the actual "success."
Larger values for Somers' D, Goodman-Kruskal Gamma, and Kendall's Tau-a indicate that the model has better predictive ability.
Summary Pairs Number Percent Summary Measures Measures Concordant 786 72.9 Somers' D 0.47 Discordant 283 26.3 Goodman-Kruskal Gamma 0.47 Ties 9 0.8 Kendall's Tau-a 0.20 Total 1078 100.0
Association is between the response variable and predicted probabilities |
For the cereal data, 72.9% of the pairs were concordant, while 26.3% of the pairs were discordant. Thus, there is almost a 50% better chance for a pair to be concordant than discordant.
Somers' D (0.47) and Goodman-Kruskal Gamma (0.47) are very close to one another because there are very few tied pairs. They tell you how many more concordant pairs exist as a percentage of the total number of pairs. Somers' D includes tied pairs in this calculation, Goodman-Kruskal Gamma does not.
